Common Functionality
Laser
: HyperBubble™
HyperBubble™
Switches the rendering of the laser survey from low density points to a high quality image.
Functionality is also available to view the high quality image using walk and fly modes, allowing for a fully immersive interactive experience of the laser survey. Refer to
Walk Mode
or
Fly Mode
for further information.
Before HyperBubble™ rendering of the laser survey can be viewed, the appropriate textures must be generated for the laser survey. This operation is undertaken using the LFM Server product. Most existing laser projects can be upgraded, for more information contact LFM support.
The loading of HyperBubble™ textures into the display uses GPU memory, the application automatically loads the most appropriate data which automatically updates as you move around the model. As graphics cards have differing memory limitations, display results may be affected. Any parts of the scene that cannot be displayed using the HyperBubble™ textures are rendered using the low density point cloud, this is typically data that is over 20 metres away from the viewing point.
