Common Functionality
Reporting : Export : Create
When you are creating a new template the Template file name is blank. When you have defined the template, you must name it by saving the settings using the File > Save as.
The Output file field displays the name of the file to which the data is exported. If no filename is given, the name of the template file, without the extension, is used. You must select one of the two radio buttons associated with the Output file field.
Select text to create an ASCII file which you can examine if the output results are not what you require.
Select binary to create a binary file suitable for reading into Review or other programs.
The Filenote field allows you to type in any text, which appears at the top of the template file, up to 128 characters, for example, to help identify the template.
You must now add the elements whose data is exported to the output file to the Include list using Add and Rem. Any elements to be excluded from the output file must be added to the Exclude list using Add and Rem.
To control how elements exported from DESIGN are displayed in the output, click Representation to display the Export Representations window.
The options available on the Export Representations window are:
You can choose how Holes are displayed by selecting one of the three radio buttons.
The Implied tube drop-down menu allows you to specify the way implied tube is managed when it is exported.
Click OK to accept the changes or Cancel to dismiss the changes made on the Export Representations window. Selecting either option returns you back to the Export window.
The way in which elements are selected for export is determined by applying selection rules. The current rule class is displayed next to the Rule Class button. To change this, click Rule Class to display the Selecting a Rule Class window.
The Selecting a Rule Class window allows you to change the rule class for the current export template and if you have the appropriate access rights to edit the list of rule classes available.
The Rule Classes list displays all rule classes currently available to you. The Class Selected and Description areas display information about the current selection. To change the rule class for the current template, select the required entry from the scrollable list and click OK.
When you select a rule class, one or more of the Delete, Modify, and Add buttons below the list can become active, depending on your access rights for editing rule class definitions. If you cannot modify the rule class, these buttons are greyed out.
To edit the currently selected rule class, click Modify to display the Modify Rule Class window.
The Add Rule Class window allows you to specify the set of rules which make up the current rule class.
You must input a Class Name and optionally a description of the Class Name in the Class Description field.
The Modify Rule Class window allows you to modify the set of rules which make up the current rule class.
