The Keep Dimensions function
applies to angle dimensions only and allows previous dimension graphics to be retained in the 3D window. If the
Keep Dimensions check box is unchecked then existing Measure Distance graphics are removed from the 3D view and are automatically removed after each new dimension is added.
The angle is labelled in the 3D graphical view, and the Measure Angle window is populated with the angle, and the direction of the two angular dimension lines.
