The Keep Dimensions function allows previous dimension graphics to be retained in the 3D window. If the
Keep Dimensions check box is unchecked then existing Measure Distance graphics are removed from the 3D view and are automatically removed after each new dimension is added.
The Show linear dimension option enables or disables display of the dimension line that goes directly between the two selected points, leaving only the orthogonal dimension lines displayed.
The Perpendicular To function allows you to draw a dimension from a graphically selected point perpendicular to a selected line or plane in the 3D model.
