Common Functionality
Query : Data Access Control
The User Rights tab displays the Data Access Controls that apply to the current user. The tab displays the ACRs that apply to the current user, and the Roles and Scopes that define each ACR.
The Element Access tab is used to view which attributes of an element you have access to, and the DAC restrictions on operations that you can carry out on the element. Where restrictions apply, the appropriate error message is listed alongside the attribute or operation.
The Query Data Access Control window is for information only. Data Access Control can only be switched on and off and changed in the ADMIN module.
