Common Functionality
Query : Attributes : Attribute Type Selection
You can specify what attributes are displayed in the Attributes window, the types of attributes selected remain the same even when the CE is changed. From the Attributes window, click the Filter arrow to display the Filter window.
By default, all of the attribute types check boxes are selected in the Attributes window, to specify what attribute types are displayed in the Attributes window, you can select from a list of available attribute types. From the Filter window, click to clear the check box for the relevant attribute type.
You can specify a custom filter, to do this from the Filter window, select Text Filters then select from the list of available filters.
Irrelevant of which filter is selected, the Custom Filter window is always displayed:
Click OK to save any inputs and close the Custom Filter window, or click Cancel to discard any inputs and close the Custom Filter window.
