Common Functionality
Modify : Properties
Click to display the Vertex Editor window. Refer to Vertex Editor for further information.
The list of properties allows you to modify the properties of an object. For example, input a dimensional value in the Width field to modify the width of an object. Select a colour from the Fill Colour drop-down list to modify the fill of an object.
When the Parameters field is active on the Properties window, clicking the button displays the Modify Properties window.
Click OK to confirm the property change and Cancel to close the window.
Controls the appearance and behaviour of the Modify Properties window. The values are automatically loaded from the user default settings. Any changes are automatically saved here.
If the check box is not selected, the element is updated only when OK on the Modify Properties window is clicked.
If the check box is not selected, a Plotfile button on the Modify Properties window displays the plotfile on request.
Graphical Dimensions
