Common Functionality
Modify
: ReName
ReName
Renames an element or an element and all its members in the database hierarchy.
Enter a new name.
Select the action to perform using the drop-down menu. The options are:
Only
The name change is applied to the current element only.
Re-name all
The name change is cascaded down to those members of the current element which incorporate the affected text within their names.
The
Re-name all
option is recommended to rename the entire hierarchy below.
Un-name
The name becomes unset (the element is then identified only by its reference number).
To modify the names of other elements, select the element in the explorer and click
CE
Click
Apply
to confirm the modification of the names. Click
Cancel
to exit the window.
