Common Functionality
Create : Standard Model Library Manager
The Standard Model Library Manager window, acts as a task hub to create the hierarchy required for the creation of standard model library items. The process is virtually identical to the creation of the hierarchy required in all applications.
When the Standard Model Library Manager window is opened for the first time a Confirm window is displayed.
Click No to load the Standard Model Library Manager window without any sample data, or click Yes to load the window with sample data.
Identifies a selected element in the Model Explorer or 3D Graphical View as the currently selected element (CE).
Select the check box to display either the Name or Description in to the Library, Library Area and Library Item box.
To create a New Library, click New Library, to display the Create Standard Model Library window.
In the Create Standard Model Library, you must now input a Name, Purpose and Description for the new library.
To create a New Area, click New Area, to display the Create Standard Model Library Area window.
In the Create Standard Model Library Area, you must now input a Name, Purpose and Description for the new area.
To create a New Item, click New Item, to display the Create Standard Model Library Data window.
In the Create Standard Model Library Data, you must now input a Name, Purpose and Description for the new item.
The Add to Standard Model Library Item pane of the Standard Model Library Manager window allows you to define what element (ZONE, STRU, EQUI, HVAC, PIPE) is to be captured. The element can then be included or copied in to library.
The selected section of the Model Explorer is displayed along with a current view of the CE.
