Press the down arrow key and select I to create multiple copies of the objects, the objects are equally spaced. The last copied object is included within the specified end point distance.
You are then prompted to Specify number of copies (Include end copy) or
Press the down arrow key and select E to create multiple copies of the objects, the objects are equally spaced. The last copied object is omitted from the specified end point distance.
You are then prompted to Specify number of copies (Exclude end copy) or
Press the down arrow key and select F to create multiple copies of the objects using a fixed spacing distance.
You are prompted Specify fixed spacing
Press the down arrow key and select A to place any surplus spacing at the base point.
Press the down arrow key and select O to place any surplus spacing equally at the basepoint and the endpoint.
Press the down arrow key and select E to place any surplus spacing at the end point.
