Common Functionality
Create
Copy
: Copy & Paste using Rotation
Copies objects using a specified number of copies and a rotation value. Each copy is rotated relative to the previous one.
You are prompted to
Select objects to copy
Click to identify the objects to copy and press
Enter
You are then prompted to
Specify base point or <Displacement>
Input
O
at the prompt and press
Enter
Specify basepoint or
Input values in the dimension fields and press
Enter
or click to identify a base point relative to which the objects are copied.
Specify number and angle or <1x10deg>
Input the number of copies times the copy angle for each copy, relative to the previous copy.
The objects are copied and the command ends automatically.
The example displays a steel section that is copied three times with a rotation angle of 90 degrees (3x90).
