Common Functionality
Create : Copy : Copy and Paste using Displacement Position
You are prompted to Select objects to copy
You are then prompted to Specify base point or <Displacement>
Input D at the prompt and press Enter.
You are then prompted to Specify displacement or
Input values in the dimension fields and press Enter or click to identify the new location of the objects. The displacement between the new object position and the original is determined by the position of the cursor in relation to the zero point of the user coordinate system.
