Common Functionality
Settings
: Explorer
Explorer
Configures the behaviour of the Explorer display.
General
Use to define the functionality and elements displayed in the various explorers.
General
Auto-collapse tree
Select check box to automatically collapse any expanded node not containing the selected CE, applies to all active explorers.
Auto-collapse tree
is disabled if
Expand to CE
is not selected.
Expand to CE
Select check box to automatically expand the tree when the CE changes (if not already expanded).
Display folders
Select check box to display folders in the explorer.
Model Explorer
Hide non-user system data
Select check box to hide non-user system data in the Model Explorer.
Show TUBI/ROD
Select check box to display all TUBI and ROD elements in the Model Explorer.
Show DB worlds
Select check box to display all DB World elements in the Model Explorer.
Draw Explorer
Hide non-writable LIBY
Select check box to hide non-writable LIBY in the Draw Explorer.
Show point worlds
Select check box to display point worlds in the Draw Explorer.
Catalogue Explorer
Show DB worlds
Select check box to display all DB World elements in the Catalogue Explorer.
Presentation
Element Type
Select check box to display the element type in the corresponding explorer.
Sort Below
Select check box to select the element type to sort by; use the functionality available to display the
Select element type
window.
