Common Functionality
Settings
: Picking Control
Picking Control
Specifies different types of offset which is applied to a picked position.
None
No offset from the picked position.
East/North/Up
X/Y/Z
Specifies a 3D offset. East/North/Up or X/Y/Z text fields are displayed at the bottom of the window (dependent on the specified world coordinates), enabling you to specify the required 3D offset.
On Plane
Specifies a 2D offset constrained to a picked plane. East/North or X/Y text entry fields are displayed at the bottom of the window (dependent on the specified world coordinates), enabling you to specify the required 2D offset.
Distance Direction
Specifies an offset as a given distance in a given direction. Direction/Distance text fields are displayed at the bottom of the window, enabling you to enter the required data directly.
From Surface
Specifies an offset distance from a surface. The Direction text field is displayed at the bottom of the window, enabling you to enter the required data directly.
The selections made are immediately set as the session defaults.
