Common Functionality
Settings
: View Configuration Options
Sets the default view configuration and performance options.
The sliders can be used to change the sensitivities of view operations. Move the slider to the right to increase the sensitivity.
Performance
Performance is used to set how the extents of a 3D model or its parts are determined by the application.
For complicated models, exact extent calculations can be time-consuming and can therefore degrade the performance of the Zoom Extents operations. If performance is an issue, it is recommended that approximate calculations are used.
