Also, by default the Attributes window tracks the CE, that is, if the CE is changed in the
Model Explorer or
3D View, the attributes displayed in the window alter to reflect the change in CE. To remove the tracking, click to clear the
Track CE check box.
Click Category Filters icon to display the Modify Category Filters window which allows you to change which categories are displayed.
Specifies what attributes are displayed in the Attributes window. The types of attributes selected remain the same even when the CE is changed. Click the
Filter arrow to display the
Filter window.
By default, all of the attribute types check boxes are selected. To specify what attribute types are displayed in the Attributes window, you can select from a list of available attribute types. From the
Filter window, click to clear the check box for the relevant attribute type.
You can specify a custom filter, select Text Filters then select from the list of available filters.
Click OK to save any inputs and close the
Custom Filter window, or click
Cancel to discard any inputs and close the
Custom Filter window.
