Common Functionality
Design Aids
Construction Aids
: Text
Text
Creates text, the text size and position in the 3D view can be defined.
You are prompted to pick the
Position
Input values in the dimension fields and press
Enter
or click to identify the text start position.
You are then prompted to select the
Text height
Input a dimensional value in the field and press
Enter
or click to identify the text height.
Text orientation or <#deg>
Input an angular value in the field and press
Enter
or click to identify the text angle.
You are then prompted to enter the
Text or
Input the construction aid text to display in the 3D view in the field and press
Enter
The construction aid text is created and displays in the 3D view. The command ends automatically.
Throughout the construction aid text creation process you can press
ESC
to cancel the command. Additional functionality is also available.
Back
Press the down arrow key and select
Back
to undo the last action.
Related Topics
Non-Routed Item
