Common Functionality
Design Aids
Construction Aids
: Fillet
Fillet
Creates a fillet from two specified construction aid lines.
You are prompted to
Pick first line
Click to identify the first construction aid line using a cursor pick in the 3D view.
You are then prompted to
Pick second line
Click to identify the second construction aid line using a cursor pick in the 3D view.
You are then prompted to enter the required
Radius
Input a dimensional value in the field and press
Enter
to define the radius of the construction aid fillet circle.
A construction aid fillet circle is created and displays in the 3D view. The command ends automatically.
Throughout the construction aid fillet circle creation process you can press
ESC
to cancel the command.
Related Topics
Non-Routed Item
