Common Functionality
Design Aids : Construction Aids : Circle Centre Point
Input values in the dimension fields and press Enter or click to identify the centre point position.
Input a dimensional value in the field and press Enter or click to identify the radius point position. A construction aid circle is created and displays in the 3D view.
Throughout the construction aid circle creation process you can press ESC to cancel the command. Additional functionality is also available.
Press the down arrow key and select Three Point to create a construction aid circle with three specified radius points. Refer to Circle Three Points for further information.
Press the down arrow key and select Two Point to create a construction aid circle with two specified points. Refer to Circle Two Points for further information.
Press the down arrow key and select Diameter to create a construction aid circle with specified centre point and diameter.
