Press the down arrow key and select Diameter to create a construction aid arc with specified diameter points.
Press the down arrow key and select Centre+Sweep to create a construction aid arc with specified centre point, radius or diameter, and sweep angle. Refer to Arc Centre + Sweep for further information.
