Common Functionality
Design Aids : Construction Aids : Bisect between Two Lines
You are prompted to Pick first line
You are then prompted to Pick end point or <Finish>
Input a dimensional value in the field and press Enter or click to identify the end point position.
Throughout the construction aid line creation process you can press ESC to cancel the command. Additional functionality is also available.
