Input values in the dimension fields and press Enter or click to identify the first point position.
        Input values in the dimension fields and press Enter or click to identify the second point position.
        Input F at the prompt and press
Enter to end the command. A construction aid line is created and displays in the 3D view.
        Throughout the construction aid line creation process you can press ESC to cancel the command. Additional functionality is also available.
