Managed hole catalogues, part hierarchies and selection tables are configured using standard functions provided in the Paragon module. Refer to Catalogues and Specifications manuals,
Introduction for instructions on creating these items. However, there are rules that must be followed when configuring this data for use in Hole Management. Catalogue data is defined, with the exception that GPART elements must have PURP attribute set to PENE.
PPEN Piping hole selection table
HPEN HVAC hole selection table
CPEN Cable hole selection table
SPEN Steel (SCTN) hole selection table
The description that appears in the Hole Management Definition window,
Hole Selection Class drop-down is the description of the Selection Table (TABGROUP). It is advisable to have unique descriptions for Selection Tables within a discipline otherwise it is not possible to distinguish between Selection Tables in the
Hole Selection Class drop-down.
Hole Selection Type drop-down is the description of the Selection Table Header (CTABLE). There can be more than one CTABLE in a Selection Table. The CTABLE description must be unique within that group.
Selection criteria are defined by the questions and answers on the Selection Tables. For example, the Hole Management Definition window below has selection criteria Gas Tight, Water Tight, Weather Tight and Fire Rating.
