When you click Pick Penetrated Items, you are prompted to identify one or more items to be penetrated with a Managed Hole. If an item already in the Penetrated Items list is selected, it is removed from that list.
Click Pick Penetrating Items, you are prompted to identify one or more equipment or sub equipment elements that contain an equipment penetration profile which defines the shape of a Managed Hole required by that equipment. If an item already in the Penetrating Items list is selected, it is removed from that list.
Click OK creates an entry in the Hole Management system, and creates a Penetration Point (DPCA element) on the equipment.
In the Equipment and Design Template applications, on the Equipment tab, in the
Tools group, click
Penetration Profile to allow an existing extrusion element to be identified as the penetration profile. The list on the window displays all extrusions in the current equipment or design template that are valid shapes for the hole management system.
Click OK on the window to create port elements in the equipment or design template which identifies the selected penetration profile to the hole management system.
