The top part of the fitting definition tab allows you to select a fitting from the catalogue. The selected fitting is displayed in the graphical view. Click Properties to display any standard modifiable common properties. Click Plotfile to display any associated fitting plotfile.
When you click Pick Penetrated Item, you are prompted to identify the panel where a managed hole needs to be placed. The position picked is the initial location of the hole, but this can be modified in the next step.
X Offset and Y Offset values for the fitting on the selected panel can be entered, and the fitting can be rotated using the spin box.
Align in X and Align in Y allows you to move the shape to a new position by aligning the origin of the shape with an item selected in the 3D view.
