Common Functionality
Hole Management System : Addition of Managed Holes : Create Penetration in the HVAC Application
A HVAC Penetration is requested, on the HVAC tab, in the Penetrate group, click HVAC, select Create Penetration from the drop-down list to display the Create Penetration window.:
When you click Pick Penetrated Items, you are prompted to identify one or more items to be penetrated with a Managed Hole. If an item already in the Penetrated Items list is selected, it is removed from that list.
Click Pick Penetrating Items, you are prompted to identify one or more penetrating items to pass through a Managed Hole. If an item already in the Penetrating Items list is selected, it is removed from that list.
Click OK to calculate the position of each penetration, and to display the Hole Management Definition window. Refer to Hole Management Definition for further information.
