Set the Specification option to display the specification of the required penetration in the catalogue.
When you click Pick Penetrated Items, you are prompted to identify one or more items to be penetrated with a Managed Hole. If an item already in the Penetrated Items list is selected, it is removed from that list.
Click Pick Penetrating Items, you are prompted to identify one or more penetrating items to pass through a Managed Hole. If an item already in the Penetrating Items list is selected, it is removed from that list.
Click OK to calculate the position of each penetration and displays the
Hole Management Definition window. Click
Cancel to exit the window.
