Common Functionality
General Facilities : Reference Browser
Use Explorer and Search tabs in the Reference Browser window to explore, select and/or search for the required owning elements in the Model, Catalogue, Draw, Schematic, Fabrication and Engineering databases for use in status layouts. By default the Model tab is selected.
If an Item Type is selected and search is carried out, all attributes bound to the selected Item Type are displayed in the Results pane of the Reference Browser window. If no Item Type is selected, attributes common to all the Item Types are displayed. By default only the NAME and DESC attributes are displayed.
To view a specific attribute bound to the Item Type in the Results pane of the Reference Browser window, click Attribute Search and select from the displayed list.
Once the search is complete the Results pane of the Reference Browser is populated with the results of the search in the following format, the two default columns (NAME and DESC) along with the additional column populated with the results of the attribute searched for.
