The Collections window is used to group data into collections and display
Search Results. You can then implement operations on all the items in a collection in one action.
The Collections window allows you to generate collections of database elements which you need to work on. Each time you access the
Collections window, in any of the modules that use it (DRAW, MODEL and SPOOL), the data collections generated is displayed enabling elements to be easily transferred between these modules.
The contents of Collections persists between applications and module switching, as well as between sessions. The data stored is per user, per project in the AVEVA_DESIGN_USER directory, for example, in Model you can add elements to Collections and then switch to DRAW to use the same data.
The Collections window consists of two parts:
When you do a search, the upper pane is minimized to show only Search Results. Click
Show All Collections to display more collections and if you want to show only the current collection, click
Current Collection. Relative size of each pane can be adjusted to display more or fewer collections.
To create a collection, right-click on a folder in the Collection grid and select New > New Collection from the right click menu. A new collection is then created and displayed in the Collections grid with a default name, for example NewCollection1.
Select the required element in the Model Explorer and either right-click and select
Add to Collections from the menu, or drag and drop the element into the Collections grid or the
contents grid.
If you have used the Add to Collections or
Add Members to Collections menu option, the element is added to the current collection.
If you have dragged and dropped the element from the Model Explorer, the element can be dropped directly onto a Collection in Collections list in order to include it in that collection. If the element is dropped outside the list of collections a new collection containing the element is created.
Unlike the Model Explorers, multiple elements can be selected in the
Drawlist, and added to the Collections grid. From the
Drawlist window right-click
Add to My Data. A new collection is automatically created containing the selected elements.
To remove an element in a collection from the Collections window, select the item row, then right click and select
Remove Selected Rows from the displayed menu. To remove a collection, right-click on the collection and select
Delete from the displayed menu.
An element in a collection can be navigated to (for example in the Model Explorer) and made the current element, select the element from the contents grid, right-click and select
Navigate To.
You can add elements from the Model Explorer to the
Collections window, right click on an element and select
ADD CE To Current Collection or
ADD CE Members To Current Collection, which will add the selected element to the current collection.
The Expression Editor window uses a PML expression to select elements.
then use the MODIFIED()syntax in the scope selection.
