It is recommended that you give the SYLB a name that makes its contents obvious to users. Click OK to display the
Symbol Library window or
Cancel to discard any changes and close the
Create SYLB window.
You must specify the SYLB dimensions, either explicitly in the Width and
Height fields, or by selecting a standard sheet size from the drop-down list.
Click Apply to create the symbol library or
Reset to revert to the values applied when the
Symbol Library window was opened.
Click Cancel to discard any changes and close the
Symbol Library window.
To select a user-defined style, click Select to display, the
User-defined styles window. A style table is selected and a selection is made from the list of styles. After selecting a user defined style, the check box is ticked by default. You can de-select this check box to use a system defined style. The functionality of the
User-defined linear styles window is explained, refer to
User-Defined Linear Styles for further information.
If you click Select next to
Hatch Pattern Colour and Style, the
User-defined fill styles window displays. The functionality of the
User-defined fill styles window is identical to the
User-defined linear styles window. Refer to
Click Apply to define the symbol library attributes or
Symbol Library Attributes window was opened.
Symbol Library Attributes window.
