Click OK to display the
Sheet Library window or
Cancel to discard any changes and close the
Create SHLB window.
You must specify the SHLB dimensions, either explicitly in the Width and
Height fields, or by selecting a standard sheet size from the drop-down list. The size is cascaded down to BACK and OVER levels.
If required, from the Ruleset Reference list, select a ruleset that defines the way in which design graphics on backing sheets and overlays are to be drawn.
Click Apply to create the sheet library or
Reset to revert to the values applied when the
Sheet Library window was opened.
Click Cancel to discard any changes and close the
Sheet Library window.
On the Units tab, select the units and set the precision.
Use the Intelligent Text tab to select an output format for the positional code words used to request the position of certain elements. These expand to a string providing the location expressed in either the ENU (East North Up) coordinate system, as an absolute position (XYZ), or as a purely numerical output (Numbers only).
Use the Pens tab to set the line colour and style. Standard options of line colour and style are set explicitly by selecting system-defined settings from the colour, line-pattern and thickness drop-down lists. Click
Pick to display the
Pick a Colour window. The functionality of the
Pick a Colour window is explained, refer to
Colour for further information.
To select a user-defined style, click Select to display the
User-defined linear styles window. A style table is selected and then a selection is made from the list of styles. After selecting a user defined style, the check box is ticked by default. You can de-select this check box to use a system defined style. The functionality of the
User-defined linear styles window is explained, refer to
User-Defined Linear Styles for further information.
If you click Select next to
Hatch Pattern, the
User-defined fill styles window displays. The functionality of the
User-defined fill styles window is identical to the
User-defined linear styles window. Refer to
Use the Miscellaneous tab to set various attributes, including note format and dimension terminator.
Click Apply to define the sheet library attributes or
Sheet Library Attributes window was opened.
Sheet Library Attributes window.
