You must name the library. It is recommended that the name makes the contents obvious to the user. Click OK to display the
Library Attributes window or
Cancel to discard any changes and close the
Create LIBY window.
When the Library Attributes window is modified all the attributes are cascaded down to the elements which use them.
On the Size & Units tab, you must specify its dimensions, either explicitly in the
Width and
Height fields, or by selecting a standard sheet size from the drop-down list.
The required Distance and
Bore units can be set by selecting an option from the drop-down lists.
Precision allows you to define the precision that is required for both linear and angular data. Four values of precision can be stored, for metric (decimal) values, imperial decimal values, imperial fractional values, and angles. By default, these four values are 0, 1, 32 and 1 respectively. Angles are stored decimally, to the nearest whole number of degrees, to the nearest minute, or to the nearest second by selecting an option from the drop-down list.
The Intelligent Text tab is used to select an output format for the positional code words used to request the position of certain elements. These expand to a string providing the location expressed in either the ENU (East North Up) coordinate system, as an absolute position (XYZ), or as a purely numerical output (Numbers only).
The Pens tab allows you to set the line colour and style.
To select a user-defined style, click Select to display the
User-defined linear styles window. A style table is selected and then a selection is made from the list of styles. After selecting a user defined style, the check box is ticked by default. You can de-select this check box to use a system defined style. The functionality of the
User-defined linear styles window is explained, refer to
User-Defined Linear Styles for further information.
If you click Select next to
Hatch Pattern, the
User-defined fill styles window displays. The functionality of the
User-defined fill styles window is identical to the
User-defined linear styles window. Refer to
The Miscellaneous tab is used to set the following attributes.
Click Reset to revert to the values applied when the
Library Attributes window was opened.
Click Apply to modify the library attributes or
Library Attributes window.
