After modifying the System Defaults window you can save the updated settings.
After modifying the System Defaults window you can save the updated setting to a new filename. Click to display a Save Defaults window which allows you to navigate to a location and name the file.
Displays the Default Load Errors window which lists any loading errors.
A confirm window displays asking you to OK re-loading of the default files. Click Yes to load the files.
The library reference defaults also display on the User Defaults window. On the Tools tab, in the Defaults group, click User Defaults. Refer to Modify User Defaults for further information.The User Defaults window is initialised with the settings from the System Defaults window after the defaults have been loaded from file. Subsequent changes made on the User Defaults window override, but do not change the settings on the System Defaults window, allowing a user some flexibility in the use of available libraries during drawing production.
