DRAW Administrator Guide
Pipe Spool Drawing Administration : Position and Populate Spool Drawing Template : Drawing Template View Format
The Function attribute on the drawing template sheet element defines the creation of view elements.
Set the Function attribute to SAME-SCALE to display the drawing views at the same scale.
Set the Function attribute to unset to display the drawing views at different scales.
Set the Function attribute to FOUR_VIEWS_ON to create four views, even if the construction of the spool does not require this.
Set the Function attribute to FOUR_VIEWS_OFF to create a single view.
Set the Function attribute to FIXED_VIEW_DIR to create the number of views and the view direction as defined on the drawing template.
