Click OK to display the
Hatching Styles window or
Cancel to discard any changes and close the
Create RPLB window.
The upper part of the Hatching Styles window displays the name of the current RPLB that is being used as a Hatching Library, and a list of all HSTYLs within it.
You must name the HSTYL and click OK. The name is added to the
Hatching Styles list and highlighted as the current selection.
Click Cancel to discard any changes and close the
Create HSTYL window.
To select a user-defined style, click Select to display, the
User-defined linear styles window. A style table is selected and then a selection is made from the list of styles. After selecting a user defined style the check box displays a tick. You can de-select this check box to use a system defined style.The functionality of the
User-defined linear styles window is explained. Refer to
User-Defined Linear Styles for further information.
If you click Select next to
Hatch Pattern Colour and Style, the
User-defined fill styles window displays. The functionality of the
User-defined fill styles window is identical to the User-defined linear styles window. Refer to
Selecting ON hatches the cross-section of a pipe or HVAC duct with a piping or ducting end symbol.
OFF hatches the full cross-section of the pipe or duct.
Click Apply to define the hatching styles or
Reset to revert to the values applied when the
Hatching Styles window was opened.
Hatching Styles window.
