The File menu item has the options;
The Task Types part of the window allows you to select a task from one of the four Task Type areas,
View,
Drawing,
Process or
Naming. Click the appropriate
Task Type, all of the available tasks of that type display in the
Tasks list.
The Tasks Definition part of the window allows you to input a name, description and function.
The Task Parameters part of the window allows you to modify task parameters.
To remove a parameter, select it in the Parameter list and click
Remove. A
Confirm window displays asking you to OK the deletion. Click
Yes to delete the parameter.
By default the Name and
Description elements in the
Tasks list are sorted alpha numerically (A-Z, 0-9). To reverse the order, click the column header of the relevant list.
If, on exit from the window, changes have been made but not saved, a Question window displays asking you to OK the modifications. Click
Yes to save any changes.
