Input the 3D position of the start point for the area in the From fields using the base product convention of
North,
East and
Up (these directions can be changed to
South,
West and
Down using the drop-down list).
        Input the 3D position of the end point for the area in the To fields using the base product convention of
North,
East and
South,
West and
        To remove the highlighted area from the Areas list, click
Remove. A
Confirm window displays asking you to OK the deletion. Click
Yes to delete the area.
        By default the Name and
Description elements in the
Areas list are sorted alpha numerically (A-Z, 0-9). To reverse the order, click the column header of the relevant list.
        Click
 above the Design Members list to navigate to the previous element in the currently selected hierarchy.
        Click
 above the Design Members list to navigate to the next element in the currently selected hierarchy.
        Click
 adjacent to the Design Members list to add the selected element in the
Design Members list to the
Selected Elements list.
        Click
 adjacent to the Design Members list to remove the selected element from the
        As items are added or removed from the area, the coordinates in the Current Volume of Selected Elements part of the window change accordingly (unless the item does not affect the extremities of the area).
        Select from the Goto drop-down list to navigate to the required element type in the
Design Members list.
        To access an element in the Design Members list that has already been added to the
Selected Elements list, select the element and click
Goto Selected.
        Click OK to set the area limits or
Cancel to discard any changes and close the
Set Area by Selecting Model Items window.
