DRAW Administrator Guide
Isometric Automatic Drawing Production
: User PML Functions
User PML Functions
To configure the functionality differently to that supplied, some areas are too difficult to organise using defaults and can only be satisfactorily controlled with the use of PML coding.
The following PML functions are supplied in the folder %PMLLIB%\isometricadp\userfunctions.
Modify the PML functions as necessary to Line projects as per particular requirements.
Some functions are called with arguments, if so then it is important that the variable names being used are not changed as these exist in the code and are used in executing the function.
