DRAW Administrator Guide
Isometric Automatic Drawing Production
Configuration
: Drafting Library
Drafting Library
IsoADP functionality has an associated library, which contains all of the required elements to produce the drawings.
Backing Sheets
Two sample Backing Sheets are supplied; an A3 metric and a 17x11 Imperial. The backing sheets can be modified, or new ones can be created as required. However the reserved areas must be maintained. Refer to
Backing Sheet
for further information.
Standard Pattern Overlay
It is possible to add a Standard pattern to the drawings using an Overlay. An example is supplied. Refer to
Standard Pattern
Representation Rules
IsoADP provides a single Representation Ruleset, which contains the Representation Rules for both HVAC and CWAY. Refer to
Symbols & Labels
IsoADP uses many symbolic and label templates, all of which are included in this library.
Material Take-Off Templates
The Material Take-Off Table can be configured in many ways and consequently the symbolic templates supporting it are also complex. The library contains the elements to enable a sorted or unsorted table. Refer to
