The Isometric ADP Defaults window displays the Isometric ADP Defaults from the supplied file named DRA-ISO-ADP. It displays the hierarchy required for running IsoADP and the essential data needed for HVAC standard drawing.
Depending on selections made in the Isometric ADP Defaults window, you are presented with further windows prompting for input.
To load HVAC standard drawings, click Load and select
Standard Drawings from the drop-down list. Refer to
HVAC Standard Drawings for further information.
The General Settings part of the
Isometric ADP Defaults window, allows you to modify Isometric ADP Defaults.
The Browse window is populated with the available registries by database.
From the Look in drop-down menu, select the required database.
Click Use to select the new registry or click
Cancel to discard any changes and close the
Browse window.
From the Look in drop-down menu, select the required library.
Click Use to select the library or click
Browse window.
From the Look in drop-down menu, select the required Ruleset.
Click Use to select the Ruleset or click
Browse window.
From the Look in drop-down menu, select the required Backing Sheet.
Click Use to select the Backing Sheet or click
Browse window.
From the Look in drop-down menu, select the required Standard Pattern.
Click Use to select the Standard Pattern or click
Browse window.
Displays the AVEVA E3D™ rule that is used to find the Electrical Cable Tray (CWAY) elements for detailing. The default (match(func of zone,|Cable Way|) neq 0) only searches in those ZONEs that have their attribute Function set to Cableway.
Input the new rule in the Rule that identifies a Cable Tray field.
Displays the AVEVA E3D™ rule that is used to find the HVAC elements for detailing. The default (match(purp of zone,|HVAC|) neq 0) only searches in those ZONEs that have their attribute Function set to HVAC.
Input the new rule in the Rule that identifies a Ducting field.
Input the new rule in the Drawing Name Rule field.
Displays the AVEVA E3D™ rule that is used to extract the Line Number from the relevant drawing elements HVAC or CWAY, and is used on the default Backing Sheet in Title Block The rule can be used within any Continuation Labels on the isometric view.
The default (replace(subs(name,2),'_',' ') uses the NAME of the HVAC or CWAY and replaces any underscore '_' characters with a blank space. The line number is stored in the UDA :IdpLineNo at the DRWG element.
A,B,C,D,E,F,G,H,J,K,L,M,N,O
01,02,03,04,05,06,07,08,09,10,11,12,13,14
Click Close to close the
Isometric ADP Defaults window, if changes have not been made.
Click Reset to revert to the settings applied when the
Isometric ADP Defaults window was opened. A
Confirm window displays asking you to OK the cancellation of changes. Click
Yes to discard the changes.
Click Save to apply the Isometric ADP defaults. A
Confirm window displays asking you to OK the changes. Click
Yes to save the changes. Click
Close to close the
Isometric ADP Defaults window.
Click Cancel to discard any changes and close the
Isometric ADP Defaults window. A
Confirm window displays asking you to OK the cancellation. Click
No to discard any changes and close the
On the Isometric ADP Defaults window, click
, to display the
Default Load Errors window, listing the elements that do not exist.
$m %PMLLIB%\isometricadp\data\Metric_Library_load.dat 5 ENU TT/
to display the
Creating the Hierarchy window, listing all writable PADD databases.
Click Apply to create the new DEPT and REGI elements or click
Creating the Hierarchy window.
The new DEPT and REGI elements are created in the Creating the Hierarchy window, you are prompted to
Load the Isometric ADP Library
Click Apply to create the Isometric ADP Library or click
Specific defaults allow you to configure components of an IsoADP deliverable. On the Isometric ADP Defaults window, click
More Defaults to display the
More Defaults drop-down list:
The Symbolic Template to be used at the start point of the spool must be set. Input the required name into the Arrive Template field or click the magnifying glass adjacent to the
Arrive Template field to display the
Browse window.
The Browse window is populated with the available registries by database. From the
Browse window.
The Symbolic Template used at the end point of the spool must now be set. Input the required name into the Leave Template field or click the magnifying glass adjacent to the
Leave Template field to display the
Browse window.
Browse window.
Select a colour from the Text Pen drop-down menu, to display in the chosen template. The label attribute is set to TXCOLOUR.
Select the character height from the Text Height drop-down menu, to display in the chosen template.
Select a colour for the frame and leader-lines from the Frame Pen drop-down menu, then select a line thickness and style from the drop-down menus. The label attributes are set to LLCOLOUR, LLSTYLE and LFSTYLE.
Select a default Offset position from the Label connection at the element by selecting
X and
Y coordinates. The Label attribute is set to XYPO.
Continuation Tag Defaults window, if changes have not been made.
Continuation Tag Defaults window was opened. A
Click Save to apply the continuation tag defaults. A
Close to close the
Continuation Tag Defaults window.
Continuation Tag Defaults window. A
No to discard any changes and close the Isometric
There are separate settings for each drawing type, select HVAC or
Electrical, from the
Drawing Type drop-down list.
Select a colour for the text from the Text Pen drop-down menu, the dimension attribute is now set to DTCOLOUR.
Input a height in the Text Height field, the dimension attribute is set to DTCH.
Select a colour for the dimension and projection lines from the Line Pen drop-down menu, then select a style and line thickness from the drop-down menus. The dimension attributes are now set to DLCOLOUR, PLCOLOUR, DLSTYLE and PLSTYLE.
To relate the dimension offset position to the actual bore of the component being dimensioned, select the Relative to Bore check box. The dimension is now incremented to suit as the bore increases or decreases.
Dimension Defaults window, if changes have not been made.
Dimension Defaults window was opened. A
Click Save to apply the dimension defaults. A
Close to close the
Dimension Defaults window.
Dimension Defaults window. A
Any of the components in the Drawing Content window, can be added to the Isometric drawing, select the relevant check box.
Drawing Content window, if changes have not been made.
Click Save to apply the drawing content defaults. A
Close to close the
Drawing Content window.
Drawing Content window. A
Refer to User PML Functions for further information on PML Functions.
From the Drawing Type drop-down menu, select
HVAC or
Electrical.
The Starting Index Number for the chosen Drawing Type must be input, use numbers with leading zeros, for example, 0001. Input the required number in the
Starting Index Number field.
Isometric Drawing Number Defaults window, if changes have not been made.
Isometric Drawing Number Defaults window was opened. A
Click Save to apply the drawing number defaults. A
Close to close the
Isometric Drawing Number Defaults window.
Isometric Drawing Number Defaults window. A
Select Drawing Type from the
Drawing Type drop-down menu. There are some differences between the options available for
HVAC or
Electrical, so each drawing type is described individually.
Select HVAC from the
Drawing Type drop-down list to display the HVAC version of the
Elevation Tag Defaults window.
Input the required name in the Template field or click the magnifying glass adjacent to the
Browse window.
Look in drop-down menu, select the required database. You must now select the registry that is used to hold the drawing.
Browse window.
IsoADP replaces the word P3 in the hash code string with the relevant P‑point number specified in the
Connection Points part of the window. Consequently
P3 must always be included in any hash code string, if the correct value is to appear in the label.
From the Text Pen drop-down menu, select a
colour for the Text that appears in the selected template. The Label attribute is set to TXCOLOUR.
From the Text Height drop-down menu, select a
character height for Text that appears in the selected template.The Label attribute is set to CHEI.
A colour, line thickness and line style for the Frame and the Leader-line must now be selected. Select a colour from the Frame Pen drop-down menu and a line thickness and style. The Label attributes are set to LLCOLOUR, LFCOLOUR, LLSTYLE and LFSTYLE.
Input the coordinates in the Offset fields. The label attribute is set to XYPO.
To tag a component that appears in a vertical leg, select the Tag in the vertical check box. The Ppoint used to tag these components can be changed by setting the value that appears in the
on field.
Elevation Tag Defaults window, if changes have not been made.
Elevation Tag Defaults window was opened. A
Click Save to apply the elevation tag defaults. A
Close to close the
Elevation Tag Defaults window. A
Select Electrical from the
Drawing Type drop-down list to display the electrical version of the
The method uses the PML Function !!isoCwayElev() and produces the following result for both multi-level and single level Cableways:
The method uses the User PML Function !!isoUserCwayElev(), which evaluates all levels and produces the following result for multi-level on the left and single level Cableways on the right:
The functionality available from the Insulation Break Defaults window is identical to that available from the
Elevation Tag Defaults window. Refer to
Elevation Tags for further information.
Insulation Break Defaults window, if changes have not been made.
Insulation Break Defaults window was opened. A
Click Save to apply the Insulation Break defaults. A
Close to close the
Insulation Break Defaults window.
Insulation Break Defaults window. A
Select a Drawing Type from the drop-down list.
The Component part of the
MDS Support Defaults window provides the information required to collect the support locations in the HVAC or CWAY main.
From the MDS Component drop-down menu, select the element type used to represent the support location
The Symbol part of the
MDS Support Defaults window allows you to select and modify the symbol used at support locations.
Select the Draw Symbol check box to create a symbol at each support location, then set the Symbolic Template to be used.
Browse window.
Browse window.
Set a scale in the Scale field, the label attribute is set to XYSC.
The Label part of the
MDS Support Defaults window allows you to select and modify the label used at support locations.
Select the Draw Label check box to create a label at each support location.
Browse window.
Browse window. The label attribute is set to XYPO.
The text functionality of the of the MDS Support Defaults window is identical to that available from the
The Dimension part of the
MDS Support Defaults window allows you to select and modify dimension settings for the support location.
Select the Draw Dimension check box to create a dimension at each support location.
The functionality available from the Dimension part of the
MDS Support Defaults window is similar to that available from the
Dimension Defaults window. Refer to
Dimensions for further information. The
MDS Support Defaults window differs from the
Dimension window in that it does not have the
Drawing Type and
Dimension drop-down lists.
MDS Support Defaults window, if changes have not been made.
MDS Support Defaults window was opened. A
Click Save to apply the MDS support defaults. A
Close to close the
MDS Support Defaults window.
MDS Support Defaults window. A
The Drawing Type must be selected, from the Drawing Type drop-down menu, select
HVAC or
Electrical.
Select the Individual component entries option button so that in an individual table, each component has its own entry in the table and is given a Position Number extracted from the database. However this can result in very long tables.
Select the Entries sorted by one field option button so that in a sorted table, all components that have the same description and parameter values are grouped together and display with a Position Number and quantity.
MTO General Defaults window.
Electrical version of the
To set the Symbolic Template to be used, input the required name directly into the Template field or click the magnifying glass adjacent to the
Browse window.
Browse window.
The functionality available from the Local Labels part of the
MTO General Defaults window is similar to functionality available in the Electrical version of the
Elevation Tag Defaults window. The
Local Labels part differs from the
Elevation Tag Defaults window in that it does not have the
Use Table and
General Template check boxes or the
Text Height field. Refer to
From the Type drop-down menu, select the component type from the list of available components.
To specify the display of parameter switches, on the Parameter Switch part of the
MTO Parameter Switching window, select the required check box.
MTO Parameter Switching window, if changes have not been made.
Click Save to apply the parameter switching defaults and then
Close to close the
MTO Parameter Switching window.
MTO Parameter Switching window. A
The functionality available from the Names Tag Defaults window is similar to that available from the
Names Tag Defaults window differs from the
Elevation Tag Defaults window in that it does not have a
Connection Points part,
Code field,
Use Template or
General Label text boxes. Refer to
The functionality available from the Isometric Origin Defaults window is similar to that available from the
Symbol part of
MDS Support Defaults window. The
Isometric Origin Defaults window differs from the
MDS Support Defaults window in that it does have a
Draw Symbol check box. Refer to
Supports for further information.
Select the Penetration from the Penetration Component drop-down menus.
The functionality available in the Penetrations window is similar to that available in the
MDS Support Defaults window. Refer to
Input an extraction rule in the Extraction Rule field to extract a string from the name of the HVAC or CWAY specification.
The functionality of the Local Labels part of the
Specification Break Defaults window is similar to that of the
Specification Breaks Default window differs from the
Code field,
Use Template and
General Label check boxes. Refer to
