BTEX attribute set to
H&S_MATL_LIST:value1, value2 where value1 and value2 specify the starting point of the Bill of Material. The position is based on the lower left-hand corner of the owning BACK size. |
REF_X:value where value sets the horizontal (X) placement of the part number hanger element in the BOM, The position is a specified distance from the left-hand edge of the BOM area defined by TEXP 1. |
DESC_X:value where value sets the horizontal (X) starting position of the hanger element in the BOM. The position is a specified distance from the left-hand edge of the BOM area defined by TEXP 1. |
DESC_MAX_CHAR_X:value where value specifies the number of characters allowed in each line of the material description. Additional characters wrap onto the next line. |
DIAM_X:value where value specifies the distance from the left edge of the BOM area where the diameter setting of the hanger element is to be placed. |
LENGTH_X:value where value specifies the distance from the left-hand edge of the BOM area where the length text of the hanger element is to be placed. |
QTY_X:value where value specifies the distance from the left-hand edge of the BOM where the quantity of the hanger parts is to be placed. |
LINE_SPACE:value where value specifies the distance between each line in the description part of the BOM. |
ITEM_SPACE:value where value specifies the distance between each part number description down the BOM listing. |
UNBOLT_PACK_EXCLUDE:word, word Not used at this release. |
LAYE_PURP:word where word specifies the distance from the left-hand edge of the BOM area defined by TEXP 1. |
BTEX set to
SLAB_SORF:name The name specified is that of the TAGR to be referenced for the support labels. |
BTEX set to
BOM:SIB Not used at this release. |
BTEX set to
HEADER_POS:value1,value2 where value1 and value2 define the position of a SLAB that references the supported item table symbol template (SYTM). The origin of the SYTM is the upper left corner of the table. |
BTEX set to
LABEL_POS:value1,value2 where value1 and value2 define the position of the first SLAB in the support item table. The position is a distance from the lower left corner of the owning BACK. |
BTEX set to
TILE_X:value where value is the horizontal distance between the reference SLABs in the support item table. |
BTEX set to
TILE_Y:value where value is the vertical distance between the reference SLABs in the support item table. |
BTEX set to
TILE_MAX:value Not used at this release. |
BTEX set to
TAGGING:name The LABEL TAGR defines criteria for the Support Table BOM and references that specific label template. |
BTEX set to
TITLE:text where text is used in the log file to mark the start of messages relating to symbolic labels in the supported item layer owned by the View. |
BTEXT
set to BOMST:STB Not used at this release. |
BTEX set to
HEADER_POS:value1,value2 Value1 and value2 define the upper left corner position of the steel BOM table. The table template (SYTM) is referenced by a SYMB that is created under a VNOT in the Steel BOM layer of the first View when the support drawing is generated. |
BTEX set to
LABEL_POS:value1,value2 where value1 and value2 define the position of the first SLAB in the steel BOM list. The position is the distance from the lower left corner of the owning BACK. |
BTEX set to
TILE_X:value where value specifies the horizontal distance between SLABs in the support material list. |
BTEX set to
BTEX set to
TILE_Y:value where value specifies the vertical distance between SLABs in the support material list. |
BTEX set to
TAGGING:name where name specifies the name of the TRST that owns the TAGRs to be used for the support items listing. |
BTEX set to
TAGGING:name where name specifies the name of the TRST that owns the TAGRs to be used for the structural support steel list BOM. The TRST has two member TAGRs, LOCAL and LABEL. These TAGRs are copied into the appropriate layer and the member SLABs that are generated reference them. The LOCAL TAGR defines criteria for locating the Part Number SLAB in the Views. The LABEL TAGR defines criteria for the Support Material Table and references that specific label template. |
BTEX set to
TITLE:text where text is used in the log file to indicate the start of messages relating to symbolic labels in the support steel layer owned by the View. |
