DRAW Administrator Guide
Label Library : Create and Modify Text Template
Displays the Create Text Label Template window. Refer to Create Text Label Template for further information.
Click to delete the selected text template from the Available Templates list. A confirmation window displays asking you to OK the deletion. Click Yes to delete the selected text template.
Click to display the Hierarchy Browser window, indicating the location of the default text template hierarchy.
Click OK to save any changes and close the Text Templates window
The Create Text Label Template window is similar to the Hierarchy Browser window. Refer to Hierarchy Browser for further information.
Browse the hierarchy to select the library element that the new template is to be created under. Input a name in the Name field, or leave it blank if the style is to be assigned a name automatically.
Click Create to create the new text template. The new text template is then created and added to the Available Templates list in the Text Templates window.
Click Cancel to discard any changes and close the Create Text Label Template window.
To copy a text template, select it from the Available Templates list and click Create a new template with starting values created from the selected one. The Create Text Label Template window displays. Refer to Create Text Label Template for further information.
Browse the hierarchy to select the library element that the new text template is to be created under. Input a name in the Name field, or leave it blank if the text template is to be assigned a name automatically.
Click Create to create the new text template. The copy of the selected text template is then created and added to the Available Templates list in the Visual Styles window.
