Cable Trays
Quick Cable Tray Routing
Quick Cable Tray Routing is used when:
The head and tail of the branch has been defined but the route between the two has not, for example: implied pipe is not shown. (ill defined route = dotted line). The mouse is used to define the direction of the cable route, bends are automatically inserted when the route changes direction.
Bad alignment between two components, where the leave direction and arrive direction of adjacent elements do not match, (this can be due to the current design tolerance settings, for example: offset, angle and ratio).
Arrive or Leave where Head or Tail is undefined, where the end directly adjacent to a component is unset or ill-defined. An unset end is where the Head or Tail has its attributes left in the default state, whereas an ill-defined end is where, when the reference is set, the position is not with the reference item or when the end reference is not set, hence the end connection is unset.
Click the dotted line (ill-defined route), which then turns green, On the
Cable Tray
tab, in the
Common
group, click
Model editor
. Refer to
Editor
for further information.
The Quick Routing Handles display at the head and tail of the ill-defined route. Ill-defined routes are where the Head or Tail of a Branch have been defined but the route between has not.
You can now create a cable tray run between the head and tail of the branch, using the mouse, the quick routing handles and the options available from the Model Editor. Refer to
Editor
A change of direction displays in the 3D graphical view and the Model Explorer as an elbow or bend (dependent upon the specification). To make the choice of elbows or bends, right-click the cardinal direction handles to display the
Model Editor
menu.
Select
Component Choice > Use Bends
