Cable Trays User Guide
Modify Cable Tray : Modify Branch
The Branch at Explicit Position window allows you to position the branch head and branch tail, set the branch width, branch direction and branch connection.
On the Cable Tray tab, in the Modify group, click Branch to display the Branch at Explicit Position window.
To modify the branch specification on the Cable Tray tab, in the Modify group, click Branch to display the Modify Branch Specification window.
Click CE to identify the equipment element as the current element. The Name and Specification of the current element display by default.
All cable tray components created below the branch use the Specification selected in the list. To use different specifications within a cable tray run, a new branch must be created at each point a different specification is used.
Click Apply to apply the selected specification to the branch, Reset to discard any changes or Dismiss to close the Modify Branch Specification window.
