Cable Design User Guide
Cableway Branch : Check Connections
Select which set of connections to display in the Cableway Branch Connections window.
Populates Cableway Branch Connections window with all the connections in the currently selected branch.
Populates Cableway Branch Connections window with all the connections in the currently selected cableway.
Populates Cableway Branch Connections window with all the connections in the currently selected zone.
Populates Cableway Branch Connections window with all the connections in the currently selected site.
Displays any relevant messages in the Cableway Branch Connections window.
If no connection errors are found, green ticks will be displayed in the Cableway Branch Connections window. A message Connections correct at this point is also displayed.
If connection errors are found, red balls will be displayed in the Cableway Branch Connection window. A message Error in connections at this point is also displayed. The connection errors will also be highlighted in red in the 3D view.
