Cable Design
Cableway Branch
: Disconnect Branch
Disconnect Branch
Use to disconnect the cableway branch from its connection points, make sure that the cableway branch to be disconnected is highlighted as the
CE
in the
Model Explorer
A
Confirm
window is displayed, prompting
Do you want to disconnect
. Click
Yes
to disconnect the selected cableway branch or click
No
to close the window and discard any inputs.
Disconnecting cableway branches means that cables will not be routed between the two branches.
