The Route Node Create Tasks window can be used as an dual purpose window, which allows the
Creation of a new route node or the
Modification of an existing route node.
Select a reference point from the drop-down menu (the Offset Distance is automatically populated) or select
Pick, a prompt to
Pick on the segment which RNODE should be placed is displayed.
Select the Mark Route Points check box to display the route point labels on the 3D view.
To display associated cables, select List Associated Cables to display the
List of Cables window, listing all the associated cables.
