Cable Design User Guide
Defaults : Auto Routing Criteria
Use to define the free-route tolerance - this is an extra 'length' that is added between the STAREF of the CABLE + First POINTR of the Free Route and Last POINTR of the Free Route and ENDREF of the CABLE. (As as the user may want to bend the cable into the STAREF / ENDREF further away than just the MINIMUM BEND RADIUS of the CABLE).
Use to switch on or off the layout cable mode (default is off).
