Cable Design
Cabling System
Cabling System
The Cabling System application creates cableways, cables and cableway material (trays/ladders). If required the cables can also be routed through the cableways. The application is divided into three main areas, Cableways, Cables and Cableway material. The cabling design process
Cableways are created early in the design process to reverse space for the cables and cableway material. Cables are selected from the catalogue and optionally connected to equipment element. Alternatively, the cables and connecting equipment could come from the Cable diagrams. Cableway material is also selected from a catalogue and added to the cableways either automatically or manually.
