Displays the Create Cable window, use to create a new cable to add to the bundle
Displays the Add cables to Bundle window, use to select cable(s) from a list of available cables to add to the bundle. Then click Insert cables to add the selected cable(s) to the bundle.
Use to remove the cable(s) from the bundle, select the cable(s) from the Cables in Bundle pane.
Use to delete the cable(s) from the bundle, select the cable(s) from the Cables in Bundle pane.
